10-04-2009, 06:06 PM   #11 (permalink)
BIGJOE
Re: reference pics Floo-tek
If you put an aluminum head on an engine that LOWERS the compression ratio, that is like a double negative. When going to an alu head, you must increase the compression ratio just to stay even with the iron heads. This situation is extreamely important on 289 engines, and almost as important on 302 based engines. I have seen 289 with alu heads, and even with a mildcam, they wont get out of their own way. If they check their cranking compression, it is 115 or 120. NO WONDER IT WONT GET UP AND GO
JOE SHERMAN RACING ENGINES
10-04-2009, 06:56 PM   #12 (permalink)
trashline
Australian A356 castings machined and assembled in USA
1.94 swirl polished stainless intake valves
1.54 swirl polished stainless exhaust valves
5 angle valve job
Hardened seats
Bronze guides PC seals hardened keepers and retainers
Double valve springs set for up to .550 lift
Hardened 3/8 rocker arm studs and guide plates
Fully assembled
180 cc intake runners
62 cc exhaust runners
58 cc combustion chambers
Flow numbers @ 28" water
Intake
.100 = 61.5 CFM
.200 = 124
.300 = 178
.400 = 209
.500 = 223
.600 = 248
Exhaust
.100 = 56.6
.200 = 98
.300 = 119
.400 = 137
.500 = 161
.600 = 191
these are the specs that I bolted onto my 289. this with a 268H cam woke the hell out of my motor. I did the head upgrade a year after the cam and intake. And for 800 bucks I could not complain AT ALL about the power gains. And with my calculations I was just under 10 to 1 compression and a .025" headgasket.
BCP Custom -> the new budget minded custom parts website
10-04-2009, 11:26 PM   #13 (permalink)
Jay C
Are those out of the box flow numbers or ported,because if that is what they say they are out of the box its not true .Ive done those heads before out of the box on my bench they flowed 210 Intake and 145 on the exhaust .
These heads can make power,and out do 289 or 302 heads if worked over correctly .the 289 heads can only flow in the 225 cfm range ,these will go in the 255-260 range ,just match the cc's of your prev heads .
Jay C is offline   Reply With Quote
10-05-2009, 02:12 PM   #14 (permalink)
trashline
Out of the box and it wasnt TSCH who tested them.
10-05-2009, 10:39 PM   #15 (permalink)
64post
These heads look a lot like FMS X305's, are they an offshore copy? I noticed the air injection holes in the exh. ports, are they c.a.r.b. legal? and for $550 were these ebay purchased?
64post is offline   Reply With Quote
10-06-2009, 02:21 PM   #16 (permalink)
trashline
550? I paid 800 for both.I think they are copies of the gt 40 swirl head. Picked them up from moneymakerracing.com
Dont get me wrong they arnt the greatest, but for a mild street car they perform better out of the box then stock heads.
Yesterday, 07:42 PM   #17 (permalink)
trashline
dropped my floo tecs off tonight at a local cylinder head shop. they are gonna cut them, CC the chambers, blend the bowls , and do a valve job for 500 bucks (hes giving me a break). Said these are basiclly pro comp heads, they flo like **** out of the box! and will respond well to the bowl work. So we shall see the results when the motor is done. I just hope I can reach my +400 hp goal.
reference source for id of motors teetrtoddr Torino Pages 0 06-23-2008 01:02 PM
9" axle reference needed. v8shadow All Ford Techboard 3 06-05-2007 12:56 PM
pics of my port work, good or bad. good reference pics.. 64 TBOLT Home Porting Cylinder Heads 1 01-10-2005 07:19 PM
Looking for parts cross reference for 1969 gal xl-gt benjiewms Galaxie Pages 2 11-12-2004 09:52 AM
Recommended Reference Manuals 4drbronko Torino Pages 1 02-20-2003 04:30 AM
