06-28-2009, 08:10 PM   #11 (permalink)
valleyfirearms
Re: Port match TFS heads
I did that several weeks ago a few barely seeped. I pulled them out today and stuck them in a drill motor. This one will make you dizzy. Well, maybe not that bad but it's definitely noticeable. This particular valve is a Ferrea F6602. I am looking at Ferrea's web site right now and they don't list this valve. Did TFS use Ferrea valves? Or I wonder if these had been replaced before I got a hold of them.
Thanks!
Mike.
06-28-2009, 09:28 PM   #12 (permalink)
n2omike
It depends upon your definition of "seep".
They should not leak at all. However, if it just barely wets the carbon in the chamber after several seconds, it's probably "ok". If it "seeps" down the chamber and down the deck of the head in just a few seconds, then there is a significant leak.
If you can see the bend in the valve when spinning it in a drill, it's BAD!
You might want to do the "gasoline test" again, and closely check out the leakers.
Good Luck!
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
06-28-2009, 09:48 PM   #13 (permalink)
valleyfirearms
The seep was a drop overnight. I had the heads tilted and that's what I found in the combustion chamber the next day. I cannot find this Ferrea F6602 on their site. It must be discontinued or maybe the number has changed.
Thanks!
Mike.
06-28-2009, 10:05 PM   #14 (permalink)
valleyfirearms
Also, would it be benefial to plug the smog holes in the roof of the exhaust ports? There is also a larger hole in one exhaust port on both heads. Would that be for the cross over?
Thanks!
Mike.
06-29-2009, 03:03 PM   #15 (permalink)
westmus
I think they do, because there are also Ferrea valves in my new TFS heads from Summit. The F6602 could be a valve made for Trickflow only.
TFS replacement valves: SummitRacing.com
westmus is online now   Reply With Quote
06-29-2009, 06:29 PM   #16 (permalink)
valleyfirearms
Thanks westmus.
Thanks!
Mike.
06-29-2009, 10:16 PM   #17 (permalink)
valleyfirearms
OK, here is goes. Let me know where I can improve. This is just the exhaust only.
Thanks!
Mike.
06-29-2009, 10:26 PM   #18 (permalink)
valleyfirearms
Looking at some CNC ported heads, I notice this portion of the valve seat has been milled down. Should I flatten this inner side? Should I flatten the bump as well?
Thanks!
Mike.
06-30-2009, 08:49 AM   #19 (permalink)
ROG30Y
actually i gotta say you didnt do to bad, and no i wouldnt get rid of the vane on the long side of the port.
make sure the short side has a nice roundness to it and make sure short side is wide enough,cant really tell by the picture.
1964 Falcon hardtop,terrible running 302 and t-5.should be a good project car....
ROG30Y is offline   Reply With Quote
06-30-2009, 10:33 PM   #20 (permalink)
valleyfirearms
Thanks for the comment. Here are some other views.
Thanks!
Mike.
Headers for Victor Jr Heads port match falcon1 Ranchero Pages 5 10-14-2008 05:17 PM
Headers for Victor Jr Heads port match falcon1 Falcon Pages 3 04-26-2008 12:51 AM
Intake manifold....match port to the heads question. RumpityRump All Ford Techboard 1 06-19-2005 10:27 PM
Port match giddyup1 All Ford Techboard 0 09-17-2004 08:04 PM
port matching Air-gap intake to match VJ heads Cman All Ford Techboard 7 10-26-2002 11:47 PM
