08-01-2009, 11:13 PM   #11 (permalink)
PSIG
Re: which heads are better?
Originally Posted by MATTBLACK View Post
So the seats on my heads are totally wasted. Would it be more desirable to go with a set of E7TE's, or would I totally screw my compression? The engine has .040 flat tops with 4 valve reliefs.
E5/E7 or GT40's would be better except for chamber sizes. They would give around 9:1 with flat tops.
Where are you located? I have a set of E7's all freshened with new bronze guides, milled, furnace cleaned and shot peened, seats and bowls machined for 1.94/1.60 valves, new valves and all - but they were for helping a neighborhood kid that wanted to hotrod for cheap and he began porting but only got 1 or 2 ports roughed before finding a cute girl. They're taking-up space and dust here. If you're interested and it helps your cause, they're $150 (less than just the valves) and you pick 'em up or pay shipping.
For a few hours with a die grinder, you could have a nice set. If you don't have porting stands (hold and swivel the head on the bench) I can throw a set in for $40 since they're bolted to the heads already... lol. I think I may have a set of stock springs/retainers I'll throw in free (or use yours), but normally you'd use what your new cam requires.
David
PS: Oh, yeah. I have a set of Ford Motorsport roller rockers I bought for the kid too. I can make a sweet deal on those as well.
08-24-2009, 08:19 AM   #12 (permalink)
jayh
as said the only difference is the combustion chambers. ive made 289 heads work really well in the past with alot of porting. you can put ford length 1.94 1.6 valves in for the same price. the extra compression will make more torque and more power
jayh is offline   Reply With Quote
GT40 heads or 1968 302 montego heads? yztrailrider Mustang Pages (1965-1973) 6 06-19-2009 10:21 PM
D0OE 351w heads to C8OE 302 heads james302 All Ford Techboard 0 04-03-2007 12:00 AM
Edelbrock Performer RPM Heads Are they good heads? Lupins All Ford Techboard 9 03-23-2005 08:00 AM
anybody looking for boss 351 heads/351c closed chamber heads? XolieX All Ford Techboard 1 01-01-2004 08:12 AM
1966 289...stock heads or 351W heads? Scooter All Ford Techboard 13 09-03-2003 07:24 PM
