Went down to the shop last night, and took a look at both heads. The 289 heads have a large bump right in the center of the exhaust port, so they must be later 289 heads. They do have obviously smaller chambers. The 302 heads have slightly larger chambers and there is a small hump in the upper right corner of each exhaust port. The valve sizes appear to be the same, and the port sizes also appear to be the same.
I realise that pretty much all stock small block ford heads are crap, but which of these would be better to modify?
Or should I look for 5.0 mustang heads?
They are going on a .040 over flat top 302. ANY advice is and will be GREATLY appreciated.
