10-11-2009, 01:01 PM   #1 (permalink)
rod123
portting and matching intake
I just had my heads ported by Les Schmader in PA but my question is should I gasket match/port the intake to match the heads on a 63.5 Galaxie 390 4sp with headers and high energy cam. He also installed CJ valves.
Rod and Alica
63.5 Galaxie 3 pedals
69 Torino Convertible
rod123 is online now   Reply With Quote
10-11-2009, 02:59 PM   #2 (permalink)
fordman460
Posts: n/a
Re: portting and matching intake
What heads and intake? Some heads have bigger ports and the bottom of the intake port should not be matched to the head.
10-15-2009, 03:08 AM   #3 (permalink)
rod123
[SIZE=2]I have already purchased a comp cam extream energy CL33-248-4 with double springs and lifters. [/SIZE]
[SIZE=2]The cam specks are [/SIZE]
[SIZE=2]RPM RANGE 1800 TO 6000[/SIZE]
[SIZE=2]VALVE TIMING 0.006[/SIZE]
[SIZE=2]LOBE CENTER ANGLE 110[/SIZE]
[SIZE=2]INTAKE CENTERLINE 106[/SIZE]
[SIZE=2]VALVE LASH HYD[/SIZE]
[SIZE=2]DURATION 274 INTAKE EXHAUST 286[/SIZE]
[SIZE=2]DURATION @ .050 LIFT 230 INTAKE EXHAUST 236[/SIZE]
[SIZE=2]VALVE LIFT 0.562 INTAKE EXHAUST 0.565[/SIZE]
[SIZE=2]LOBE LIFT 0.327 INTAKE EXHAUST 0.327[/SIZE]
[SIZE=2]VALVE TIMING @0.006 LIFT[/SIZE]
[SIZE=2]INTAKE OPEN BTDC 31 CLOSE ABCD 63[/SIZE]
[SIZE=2]EXHAUST OPEN BBDC 77 CLOSE ATDC 29[/SIZE]
[SIZE=2]I do not have locks,valve seals,hardened seats or retainers.[/SIZE]
[SIZE=2]I also have a new set of stainless valves stock size CJ but if they are not a good for what we are doing I can sell them on ebay.[/SIZE]
[SIZE=2]The car will have two afb four barrel carbs the cfm I think is around 600 each.[/SIZE]
[SIZE=2]4 sp tranny I do not know the tranny ratio but I will see if I can find out.[/SIZE]
[SIZE=2]Long tube ceramic coated headders.[/SIZE]
[SIZE=2]3.50 gears posi out back.[/SIZE]
[SIZE=2]MSD electronic ignition.[/SIZE]
Deep oil pan with melling high vol pump.
Rod and Alica
Port Matching Intake? growlin351w All Ford Techboard 15 10-31-2003 06:49 PM
Intake/cam mixing and matching voot61 All Ford Techboard 6 08-25-2003 11:54 AM
Port Matching Intake? growlin351w All Ford Techboard 4 07-10-2003 12:06 PM
Port Matching Intake hirtr All Ford Techboard 2 08-14-2002 03:28 AM
Port matching the intake on a 429 ??? JD466 All Ford Techboard 1 01-21-2002 05:14 PM
