Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Ignition Articles
09-19-2008, 02:39 PM   #11 (permalink)
marzz22
Re: Ignition resistor wire removal 1973 torino
I'm not understanding something. Do I need to 'replace' the R/LG wire from the ignition switch to the junction block or 'add another' 14 gage wire along with the R/LG wire? Please excuse my ignorance as I do not understand automotive wiring. I do however want to have my car working properly.
"Long Live the Cleveland"
marzz22 is offline   Reply With Quote
09-19-2008, 04:10 PM   #12 (permalink)
rcodenewf
Replace the resistor wire from the switch to the block but then as previously stated, include the bypass wire so the coil gets full 12volts while in the 'crank ' position.
I did the same procedure on my 69 but left the old resistor wire in the harness and ran a new red one from the switch forward.
Hope this helps....John
1969 Fastback-1 owner-302 TFS Heads, Bigs 650 DP, Comp Xe262, Speedpro Rollers, Vintage S2MS Cobra intake, Flowtech Ceramic Headers, C4- JPT valve body, 2600 stall, 3:55 Detroit.
1969 Mach 1, 428CJ, 4 spd, 3:50 trak loc; unrestored
rcodenewf is offline   Reply With Quote
10-03-2008, 11:09 PM   #13 (permalink)
NeverRight
Why would this matter with an MSD setup?
The coil gets its power from the MSD, and the MSD gets its power right from the battery. (The large gauge + and - wires)
The small positive wire from the original coil + is just the trigger wire to turn the MSD box on.
If you're just running a hot coil and a factory style ignition that still uses the factory coil + wire to feed the coil, then I can see this being a good idea. Or like the OP with this wire feeding a RTR(ready to run) hot dizzy.
NeverRight is offline   Reply With Quote
10-06-2008, 11:32 AM   #14 (permalink)
fordpwr4u
Angry Re: Ignition resistor wire removal 1973 torino
unrelated but you look like a wiring guy.
I have a 351 Boss, dual point.
I checked the total timing on it and wow was about 60+
So I unhooked the vacuum and set the total about 32 and initial is about 12
So all good. Took it for a drive and car feels like a dog won't pull hard.
Factory carb seems ok. But will not let the horses out.
I have had this problem before even with stock ford electronic, was 60 plus too
Everybody should be checking total timing not setting it at idle. I cant imagine how many motors ford wrecked with their crap ignition.
I am tempted to put MSD in but want to keep it stock, but if it wreckes the motor!!!!!
Good info on Torino - if anybody has 72 sport FB for sale let me know (4speed be a dream)
fordpwr4u is offline   Reply With Quote
HTML code is On
ignition resistor wire 1972-73 torino ramair351 All Ford Techboard 4 08-25-2008 08:57 PM
stock wire harness, resistor location question 54bomb Galaxie Pages 3 09-14-2007 12:06 AM
help with resistor wire for pertronix please eyechsr All Ford Techboard 10 05-05-2007 07:02 AM
429/460 ignition wire arrangement!!!! XolieX All Ford Techboard 4 12-26-2003 11:20 PM
Ignition Resistor Wire? Rancho Lenny All Ford Techboard 1 09-25-2002 08:26 PM
