Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Ignition Articles
08-25-2009, 07:03 PM   #1 (permalink)
F15Falcon
MSD Blaster SS Coil Mount
I bought the MSD Blaster SS coil (part number 8207) for my '64 Falcon wagon. It is a nice compact coil that delivers 40,000 volts of spark, brass terminals, and a Rynite housing. It comes with rubber isolators that allow it to mount to the inner fender wells or radiator support. I did not like the fact that I would end up with a very long coil wire if I were to mount it to the fender wells. I decided to build a mount that would allow the coil to mount on the drivers side cylinder head allowing a shorter coil wire. I mounted the coil on a 351 W, but he procedures shown will work on any Ford engine family by drilling the appropriate holes.
I measured between the holes to determine the size of material needed:
I used a piece of 2" x 4" x .120" rectangular tubing and cut an angle piece out of it using a cut off wheel on my ever present 4 1/2" angle grinder:
The holes that would mount it to the head are marked and drilled:
A test fit showed that it fit well:
Some profiling and trimming made the bracket look more streamlined and not like it belongs on a tractor:
The coil is lightly clamped to the bracket, and a transfer punch is used to mark the mounting holes, and the holes are drilled:
The coil is mounted via the rubber isolators and the job is done:
08-26-2009, 05:48 PM   #2 (permalink)
rmousir
Re: MSD Blaster SS Coil Mount
excellent job! Looks great!
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
08-27-2009, 12:19 AM   #3 (permalink)
MusclePoney
Thumbs up Re: MSD Blaster SS Coil Mount
X2!!
MusclePoney is offline   Reply With Quote
HTML code is On
MSD Blaster 2 coil ponyexpress All Ford Techboard 2 04-02-2006 01:06 PM
MSD Blaster 2 coil... adgdghr123 All Ford Techboard 4 05-24-2005 05:49 PM
MSD SS BLASTER COIL & DURASPARK 2 TheGmKiller331 All Ford Techboard 8 01-15-2005 09:51 PM
blaster 2 coil or newer HVC coil???? billy All Ford Techboard 3 06-08-2003 11:18 PM
MSD Blaster 2 Coil Torino500351C All Ford Techboard 0 06-13-2002 02:46 AM
