Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Induction Articles
08-08-2009, 09:54 PM   #1 (permalink)
F15Falcon
Electric Fuel Pump Mount
Here is a simple electric fuel pump mount that mounts the old Holley style electric fuel pump underneath a '65 Mustang. I wanted to mount the pump near the fuel tank outlet, but I also wanted to be able to remove it easily for service.
This is the Summit fuel pump that I would be using. It is basically like the Holley red, blue and black fuel pumps. It comes with a mount, but there was not a good place to mount it underneath the '65 Mustang I am working on:
I made a simple bracket from 2" x 1/8" thick angle iron. I drilled the holes that would bolt the pump mount to the bracket, and also the holes that would hold the bracket to the floor. I then welded 1" long 5/16" studs into the holes to make installation far easier than using bolts:
I drilled the holes that would hold the bracket in the floor of the car, the holes would also pass through the fuel tank mounting flange:
The bracket was now bolted to the floor:
The pump is bolted to the bracket:
Bottom view:
I installed a filter before the pump because one of the things that will kill an electric pump is trash, so a little insurance now will pay off later:
We now have a simple, sturdy mounting system that is easily serviceable, and looks pretty good.
08-16-2009, 02:11 PM   #2 (permalink)
68FalconSC
Re: Electric Fuel Pump Mount
Looks nice and clean. I really like having a filter between the tank and pump. Makes sense to "keep the trash out". Jon
68FalconSC is offline   Reply With Quote
08-19-2009, 03:54 AM   #3 (permalink)
elwood
nice execution with the studs and all, similar to what i did on 'The Turd'
how loud is the Summit pump? my Holley Blue's annoying as all get-out.
elwood is offline   Reply With Quote
08-31-2009, 09:33 AM   #4 (permalink)
jmanley
What you might want to do is get some flat rubber sheets and cut them to go between the bracket and the frame, as well as between the bracket and the pump. That'll help to some extent.
Jay M
Fargo ND
1972 Mustang Mach 1
351C-CJ
jmanley is offline   Reply With Quote
09-15-2009, 07:09 AM   #5 (permalink)
jrnice
X2, the vibration will carry through the floor like crazy.
jrnice is offline   Reply With Quote
09-15-2009, 07:31 AM   #6 (permalink)
n2omike
If you want it as quiet as possible, mount it on an old "strap" style muffler hanger.
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
HTML code is On
electric fuel pump 66fastback All Ford Techboard 14 10-13-2006 11:25 AM
Electric fuel pump 347LX All Ford Techboard 2 07-17-2006 02:23 AM
electric fuel pump vs. manual fuel pump JoeD All Ford Techboard 13 06-30-2005 07:23 PM
Electric Fuel pump? 69fstbk All Ford Techboard 2 01-02-2005 01:04 AM
Mechanical fuel pump VS. Electric fuel Pump growlin351w All Ford Techboard 16 08-01-2003 09:28 PM
