Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Interior Articles
06-25-2008, 09:12 PM   #1 (permalink)
rmousir
Late Model Seats in a 1966 Mustang
I really wanted to upgrade my stock seats. They were in rough shape and needed to be rebuilt. I wanted to add head rests and get a better feel from them. The cost of the ‘new’ kits was more than I could afford. After a lot of surfing and reading about using newer mustang seats I found a set of black leather seats that were almost free.
I drove about 4 hours round trip to pick them up. They are in great shape and look good. I even got the back seat incase I want to do another project later.
The stock seats on a old mustang sit very low to the floor. There is not a lot of room to make adjustments. I have seen where some folks have modified the seat pan but I didn’t want to do that. The ’96 seats sit much higher due to having the ‘power adjustable’ option. This is really such an easy mod I am surprised that everyone is not doing it.
1.Get your self a good seat of seats and recover them if you like. Lots of cool custom things can be done here so the sky is the limit.
2. Remove the seat tracks from the ’96 seats. This will bring them down to almost the same height as the stockers. Keep all of that power stuff and what not. I was able to sell mine for $30. Also keep the bolts that are used to bolt the track on to the seat.
3. Remove the stock seats from your car. Be sure to keep the tracks so you can bolt them up on your new ’96 seats. Also be sure to save the bolts that bolt on the tracks to the seats.
4. This is a good time to clean up the old seat tracks. Replace the springs if needed. Clean and grease them. Make sure the bolts and nuts are in good order. I painted mine, bought new nuts, and new floor plugs.
5. Once the tracks are cleaned up you will need to do two modifications.
5.1 The seat adjuster that you would normally push to the side so you can adjust the seat back and forty, you will need to bend this almost flat because the seat will interfere with the lever’s operation.
See adjuster handle has been bent almost flat to match the contour of the seat.
5.2 The holes to bolt the stocker tracks to the ’96 seats will not line up 100%. I took and used the front hole and lined it up with the front hole on the ’96 seat and found that the back of the track lined up and if I notched the track a little I could bolt it right on. If you put the track in place and bolt in the front you will see where you will have to either drill a hole or notch the track. I figured notching was easy enough so I did so.
The first time I got the track on and tightened up I found that when testing it I could not get it to slide well. This is because the leather bottom of the seat was rubbing against the track and stopping it from freely moving.
To correct this I decided a small spacer was needed. I used two nuts for each track just to see if would work. I used a small piece of electrical tape to do this and it worked just fine. I tapped the nut to the chair to provide a little space between the track and the seat. I have driven the car with them taped into place since but I think that when I pull the seats out I may find another way to do that. Maybe tack-weld them on the rail.
See below the hole for the bolt is my nut with some electric tape.
See seat with track installed.
Once you have the tracks on put your new ’96 seats in your car and bolt them up. I recommend using the seat track clips, new seat track nuts for underneath, and new or good conditioned body plugs to seal up the bottom.
Adjust as needed and enjoy
I think they look pretty good. I am pretty sure that I can get the back seat to fit in and look good as well. It is narrower than the old stocker but it will complete the interior I think. What do you think?
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
06-29-2008, 05:56 PM   #2 (permalink)
beegshot
Thanks for the tip. A question...
How tall are you? The reason I ask is that I'm 6' 2"...and long waisted. My hair rubs the headliner in my '65 with stock seats. Are the seat bases on the late model seats any higher than the stock seats? I'm prepping my car for my wife to drive, but don't want to make it so I can't drive it also.
Robert
http://www.fordmuscle.com/pics/beegshot_a.jpg
Beegshot
2 - 65 'stangs, 79 F100 SuperCab, 03 Expedition
Henry Ford said, "If you find you need a tool, you have already paid for it."
06-29-2008, 07:17 PM   #3 (permalink)
rmousir
Re: Thanks for the tip. A question...
I am 5'7". I would say the seat bases are about 1" taller. I didn't find that I really sat much higher than before with exception that my steering wheel is a little closer to my legs. I find that is the major difference. I am able to easily deal with anything else because these seats adjust back and forward and recline easily. I also plan on a smaller steering wheel.
I am pretty sure that the older fox body seats are shorter in the base than these seats are.
If you wanted you could just set a seat in there that you might put in and get a feel for it. I know that these seats are 100% more comfortable than the old stock seats and, for what I paid, a fraction of what it would have cost for new or custom seats.
Richard
1966 Mustang Coupe
06-29-2008, 07:18 PM   #4 (permalink)
rmousir
One more thing, if you get these grab the seat belt clamps that sit under the head rests (the plastic things that guide the belt). I have them and think they will work well with a 3 point seat belt set up that I am working on.
Richard
1966 Mustang Coupe
HTML code is On
Late Model Seats into your Classic Ride strtcar Interior Articles 15 06-20-2009 11:20 AM
Late Model Mustang Seats strtcar Wanted 2 10-15-2007 03:27 PM
Late model Mustang Ranchero. danv Ranchero Pages 10 08-28-2007 07:29 PM
late model seats in a 67 mustang? 67bullitt All Ford Techboard 0 12-16-2004 02:04 PM
Late model seats in early model mustangs fordfreak65 All Ford Techboard 7 08-25-2003 01:29 PM
