Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Interior Articles
08-16-2009, 11:15 PM   #1 (permalink)
rmousir
Budget Insulation
With new floors, new Dynamat, and new carpet on its way, I started looking for some good insulation for my '66 Mustang. My biggest problem with driving my Mustang is the heat that comes with these old cars. The motor does a good job of cooking you out. I like to do everything I can from what I read, insulation appeared to be something that can make your hot rod much more enjoyable. There are a lot of benefits to convince you to do this job but the costs can be a huge deterrent. But don't put this project off because of costs just yet.
I found a lot of different products out there. I figured that my top pick would have been Dynamat's product because of the great experience I have had with them on the sound deadening stuff but the cost killed it. Continued research pointed me to some bubble insulation stuff that I found. After more digging I found that this stuff would start out good but then not finish so strong. The bubble stuff will pop when you get in and out of the car. This will kill any benefits it can/would provide. So that is out.
So I am reading one night on a local hot rod forum and a poster there described a great product that sounded perfect and the best part is that I could get it locally for very little out of pocket. What is this great stuff? It is called Thermwell 12 In. x 15 Ft. x 1/8 In. Self-adhesive Foil/foam Duct Insulation and you can get it at your local Home Depot for under $20 a roll. I purchased a roll so I could see if this really is the product for me.
Check it out here: Thermwell
What is so good about this you say? Well it won't absorb water, it won't grow mold, it is foil backed (the thickest foil I found on any of these products), it keeps the hot and cold out, it kills sound, it is easy to work with, and most of all, it is CHEAP! It also has an adhesive backing so it sticks and stays in place pretty well. Now that I had decided that this would suit my needs I picked up two rolls, some aluminum tape, got out some old scissors, and went to work.
I slowly started cutting pieces about 1' long and started putting them in place. I did have my heater out at the time so I was able to do a pretty good job at covering the fire wall. I went as high as I could and to be sure it would stay I used a little 3M sticky spray.
Once I had to the fire wall done I moved on to the passenger side and worked towards the back of the car. I would cut a piece and put it into place, then move on to the next piece. Each time I added a piece I would use the aluminum tape and use it to cover all the seams.
So after a couple of hours on a cool evening I was done. This is one of those projects that you want to take your time with and not get in a big hurry. I ended up using two rolls plus a little material off a third roll but I had some mistakes so maybe you can get it all done with two rolls. I have lots of tape left and only used the 3M spray on the fire wall.
The results are great. I started the car and can already hear a big difference in the sound. With this being a product used for home a/c & heating ducts I have no doubts that it will do a good job of keeping the elements at bay. Best part is that I did this entire project for under $50 because I already had the 3M in the garage. Now on to the carpet!
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
08-18-2009, 08:41 PM   #2 (permalink)
HankyJ
Re: Budget Insulation
Hey Richard, great article. Only wish I had seen this one before I invested in Dynamat. Well, we're working on my niece's '67 'Stang so will have a chance to use this.
HankyJ
08-18-2009, 09:07 PM   #3 (permalink)
Juan
Yes, I have been using the product for some time in my 67. Works great good show. John--Las Vegas
Juan is offline   Reply With Quote
08-20-2009, 03:29 AM   #4 (permalink)
MrBear
Very nice write up indeed. I'm looking for something just like this for my insulation project.
Did you notice any differencies between the foam duct insulation and Dynamat e.g.? In one of your pics I see Dynamat on half of the area. Is this something extra you added?
MrBear
MrBear is offline   Reply With Quote
08-20-2009, 07:37 AM   #5 (permalink)
rmousir
the dynamat is the sound deadner only. It cuts down on the vibrations in the car. There are some heat/cold insulation properties with the product but it is mainly for sound. They also sell a insulation for hot/cold but it was beyond my budget.
What I did is install the dynamat to to sheet metal (body/floor) for the vibrations/solid sound and then put the insulation on next with total coverage. Then cover with a nice carpet. You can of course just use this with out the dynamat.
I have a write up on the dynamat that I got here:Dynamat - Budget Restomod Mustang
Hope that helps.
Richard
1966 Mustang Coupe
08-21-2009, 02:00 AM   #6 (permalink)
MrBear
Just purchased some of the foam insulation. Looking forward to get started. At the moment the 65 LTD only have a carpet and no insulation and Flowmaster 40's... I hope it will take some noise and vibration along with the heat/cold insulation.
HTML code is On
Carpet & Insulation fordclevor Falcon Pages 5 07-01-2008 02:23 PM
What to use for headliner insulation? 64GALAXIE514 Galaxie Pages 8 09-06-2006 06:43 PM
garage insulation? mels65 The Garage 3 01-25-2006 10:43 PM
Firewall insulation retyler Falcon Pages 4 01-19-2006 07:38 PM
Best floorboard insulation? Jimmys66 All Ford Techboard 11 01-11-2002 04:50 PM
Probe Industries
