Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Interior Articles
11-12-2009, 06:11 PM   #1 (permalink)
rmousir
White Gauge Overlays
My dash is not the best looking. I think it could really use some custom touches but with keeping my budget tight I don't have a lot of options. I would love to have the money to get one of the aluminum bezels with the nice high end white faced racing gauges but I don't. The problem I see with that is this. The basic stock ford gauges when properly hooked up do a fine job of letting me know what I need to. So I don't see a reason to change them. Not sure there is a huge benefit for my money. What I don't like about the gauges is the back back ground. This makes them harder to read in my opinion, especially at night. So what is the solution?
I had read about this kit in the magazines and even saw them at the vendors shops but they always wanted what I thought was an inflated price for this product. So I got on to ebay and started looking at gauges and found that I could get this kit for around $20 from a vendor named 'customegauges'. They were great to deal with and everything was as promised. With my new white gauge overlays in hand, I removed my bezel and cluster and got to work.
A while back I picked up a very nice 66 GT black case bezel. I figured this was as good a time to put it into my car as any other time. I pulled things apart and found that I had one blown bulb so I decide to replace all the bulbs. This is a good time to upgrade to LEDs if you like. Before I install my overlays I wanted to freshen up the needles. For this task I talked my wife into donating her time and some nice red finger nail polish. I figure it is as good as model paint or a sharpie marker. It turned out pretty good!
To install the overlays, I used some Q-tips and a glass of soapy water (dish soap). I dipped the Q-tip and swabbed it on the surface of the gauge face. Then I carefully pealed the gauge overlay off the backing and carefully placed in to position. With the soapy water you can slid it around and adjust as needed. Once it was all lined up. I used some dry clean Q-tips to push out the soapy water and bubbles. Then again using Q-tips I dried off the gauge edges and face. Now I have a white gauge face! I continued with the same steps for the rest of the gauges.
Once everything is all done the results speak volumes. I am very happy with how easy it is to do. I am confident that my 5 year old could do this. What do you think?
BEFORE
AFTER
Looks much better now. A little pop with out screaming look at me!
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
11-12-2009, 07:57 PM   #2 (permalink)
351cid
Re: White Gauge Overlays
I'm in the process of doing my Ralleye Guages for my Torino. I found these overlays to be top notch and as advertised. I was very impressed with them...especially for the price.
351cid is offline   Reply With Quote
11-15-2009, 08:40 AM   #3 (permalink)
347falcon
How do I find the on ebay. I tried customegauges and that did not work
Thanks,Rick
347falcon is offline   Reply With Quote
11-15-2009, 11:12 AM   #4 (permalink)
Fantastic
I think the white looks nice, but I would have opted for a brushed aluminum foil so that it blended with the rest fo the dash even more. I'm surprised someone hasn't made a replacement set that are CNC cut so they can be lit from behind.
Please don't take this the wrong way. You have achieved your goal and they look great. I'm just thinking of other options that might also work well. Heck...If I could only get to this level. I'm still desparately trying to get my car back from the painter!!
Fantastic is offline   Reply With Quote
11-15-2009, 03:31 PM   #5 (permalink)
jvercellino
Richard, I also completed the white overlays on my '65 Pony interior. It made a huge improvement. Like you, I also installed LED replacement bulbs. I used blue colored bulbs because that matches my interior.
jvercellino is offline   Reply With Quote
11-15-2009, 06:04 PM   #6 (permalink)
rmousir
Thanks,Rick
Here is there ebay store:
eBay Store - White Gauges: Chevy, Ford, Mopar
Hope that helps.
Richard
1966 Mustang Coupe
11-15-2009, 07:20 PM   #7 (permalink)
347falcon
The 64-66 Mustang looks like the dash in my 65 Falcon do you think they are the same
Thanks, Rick
11-16-2009, 08:19 AM   #8 (permalink)
rmousir
I am not 100% sure, but I believe they are the same part. Someone here might jump in and confirm that.
Richard
1966 Mustang Coupe
01-17-2010, 09:16 PM   #9 (permalink)
Comechero65
Thanks, Rick
White face overlays for the 64 1/2 - 65 Mustang will fit the 64/65 Falcon cluster perfectly. Also overlays for the 5 gauge 66 Mustang cluster will also fit the 65 Comet cluster.
RS
Comechero65 is offline   Reply With Quote
HTML code is On
Emblem overlays hofs01 Galaxie Pages 2 02-23-2009 08:35 PM
Ford Galaxie Front Grill and Rear panel overlays Greg B Galaxie Pages 2 02-18-2008 09:29 AM
White letter out or white letter in on tires? DynoTom Galaxie Pages 16 05-19-2005 10:42 PM
85-140 mph white face gauge swap...need help... hot87gtstang All Ford Techboard 0 08-14-2003 01:11 PM
Well, it is white now..... Just Strokin Fairlane Pages 1 09-15-2002 11:02 PM
