Stock upper efi manifold porting
I ported the upper and lower on a car I had toll this spring, a 92 LX 5.0. the intake you have is aluminum, so it is very soft! Remeber that. Remove it from the lower and gasket match it when porting the eight runners. I used a carbide bit on a air die grinder, and followed that up with grinding stones using the same die grinder, and finished up with sand paper, going from coarse, (220) to fine, (600). Go as deep as your grinder will go. Not sure about your intake, but pay attendtion to the passage turns and always keep wall thickness in mind, dont wanna grind through...
On the thottle body side, hog out the opening to match your throttle body, 65mm or what ever your running. Same procedure. Go slowly, and remember to remove all flak and dust from the manifold with both water and compressed air before reinstall. Have fun!
