EFI problem........?
unfortunately, diagnosing isn't my strong point, but my sister had the same problem. Turned out the computer was cooked. I don't think their fuel pump continued to run. Problem is, it could be any one of a hundred problems. The best thing to do is go to wal mart and buy a ford code reader. They have them in the automotive section. Best 25 bucks you ever spent. Basically, you plug it into the wiring harness, and it blinks a series of lights that correspond to codes in the book that comes with it. That should tell you what isn't working. Once you get the codes read, post again and you may get more help. good luck.
