Mystery "Check Engine" light
Just FYI, an O2 sensor code is pretty normal for Key On, Engine Running if the car isn't hot, or if it has been idling for awhile. Under those circumstances, the O2 sensors get a little lazy and stop switching, so the computer thinks it's either lean or the O2's are bad. I would say the Neutral switch code is your only problem.
-Brian
