02-24-2003, 10:23 PM   #1 (permalink)
BJ68
SOHC Engine to DOHC Engine
Anyone have experience in swapping a SOHC engine to a DOHC engine?
BJ68 is offline   Reply With Quote
02-26-2003, 01:24 AM   #2 (permalink)
fastback.brian
? Swapping engines or swapping heads ?
fastback.brian is offline   Reply With Quote
03-01-2003, 07:55 PM   #3 (permalink)
BJ68
The complete engine.
03-02-2003, 12:19 AM   #4 (permalink)
tonyk
Do the heads swap on the 5.4L 3 valve motor to the DOHC 4 valve?
Is the swap worth doing?
tonyk is offline   Reply With Quote
03-07-2003, 08:01 PM   #5 (permalink)
fastback.brian
In still waiting for the 3 valve heads to arive out here. As far as the sohc to dohc swap goes its easy. they both use the same mounts and tranny setups. exhaust manifolds are differnt as are the intakes. there is alot of little things that will need to be changed but can be simple.
03-08-2003, 10:56 AM   #6 (permalink)
dpfalls
What about the computer/harness? This is a swap I may be interested in performing in the future. I can get the SOHC 4.6 relatively cheap. Upgrading later may be the way to go. I think I would switch to forged pistons before I did a conversion on the engine. How much work would changing the engine itself be? I can think of the heads/cams/intake/and exhaust.
dpfalls is offline   Reply With Quote
03-10-2003, 10:20 PM   #7 (permalink)
fastback.brian
Head swapps can get tricky. but engine swapps can be easy if a dohc was offered in the same model car with a sohc. So to swapp a 99 cobra engine into a 99 gt would make things easer than swappin in a 96 mark8 engine Or goin from a v6 to an 4.6. But parts are out there so anything is posible with the mod engines.
Holley
Holley
