Help! serpentine belt headache
I'm not sure on the length of belt but you can do this if you don't want to keep the smog pump.
Starting at the alt., belt goes under the tensioner around the AC comp. down to the PS pulley, then up and around the pass. side of the WP pulley and around the driver's side of the crank pulley and back up to the alt. If you don't have AC, belt goes around the PS (mounted up high from Ford if it's factory and untouched) then toward the pass. side of the WP pulley and around the driver's side of the crank pulley to the alt. pulley. Hope this helps.
Tony
ps.... to determine length of belt run a piece of string around the pullies in the correct order mentioned then measure and get the correct length of belt, maybe subtract an inch or so to take into account the tensioner.
