10-25-2003, 02:13 AM   #1 (permalink)
SPEEDLEECH
TIMING 5.0 Mustang
I need to know if im doing this right. I pulled out the jumper and adjusted the timing to 10 degrees using timing light. I then put the jumper back in and the timing jumps to about 12-14 degrees. The question i have is do i set the timing so it reads 10 degrees with the jumper in? If so does the timing always read hiher with the jumper in? I know...Bone Head stuff. I appreciate your time.
SPEEDLEECH is offline   Reply With Quote
10-25-2003, 03:08 AM   #2 (permalink)
1 Bad 88 GT
TIMING 5.0 Mustang
Yes, always set/check timing with the SPout connector unplugged. The connector allows the 'Puter to interface with the dist and vary timing as needed so it will constantly change.
10-25-2003, 05:54 PM   #3 (permalink)
67stang
TIMING 5.0 Mustang
yes you did it correctly. though 10 is kinda low, get it to 12 without the spout.
10-26-2003, 04:17 PM   #4 (permalink)
SPEEDLEECH
TIMING 5.0 Mustang
THANKS! TO BOTH OF YOU.
11-06-2003, 12:52 PM   #5 (permalink)
tbirder
TIMING 5.0 Mustang
Can anyone take a pic of the spout connector under your hood. I've had discussions before about this on my 89 tbird, I can't seem to find on on my car??
tbirder is offline   Reply With Quote
11-06-2003, 05:32 PM   #6 (permalink)
fogged408w
TIMING 5.0 Mustang
On a 5.0 foxbody it should be a small plug thats on the wiring harness within 1ft of the dizzy.
on a 98 bird? they might have moved it?
