01-20-2004, 08:19 PM   #1 (permalink)
tempercontrol
5 lug conversion
What is the easiest way to do a 5 lug/4 wheel disk brake conversion on a fox 1990 mustang?
tempercontrol is offline   Reply With Quote
01-20-2004, 10:10 PM   #2 (permalink)
deleted2
5 lug conversion
Use SVO rotors in front, new are $99. I've heard Ranger axles in the rear but I just indexed a set & re-drilled them
01-20-2004, 10:10 PM   #3 (permalink)
1 Bad 88 GT
5 lug conversion
A complete SN95 kit.
01-21-2004, 01:13 AM   #4 (permalink)
1 Bad 88 GT
5 lug conversion
I used Mark VII front rotors on my 80 and 88, thye're 1/2 the price of the SVO pieces. For the disc rear use SN95 axles, rotors and calipers.
01-21-2004, 06:36 AM   #5 (permalink)
tempercontrol
5 lug conversion
Is SN95 a Ford part number?
Will a Mark VII be the same bolt pattern?
<font size=-1>[ This Message was edited by: tempercontrol on 1/21/04 5:37pm ]</font>
<font size=-1>[ This Message was edited by: tempercontrol on 1/21/04 5:38pm ]</font>
01-21-2004, 09:16 AM   #6 (permalink)
deleted2
5 lug conversion
New the SVO &amp; Lincoln are the same price &amp; part number. The SN95 conversion is really pricy. Machine shop can redrill the axles &amp; drum cheap.
01-21-2004, 12:37 PM   #7 (permalink)
PONY1
5 lug conversion
I've got a brand new set of rotors with 3" moroso studs, calipers, new bearings, hoses and spindles from my 1983GT that I'm selling cheap. About the same price as a set of rotors. I'm also throwing in a 2nd set of Carbon Metallic brake pads. Check here if your interested.
http://bbs.hardcore50.com/ads/index.php?item=6297
PONY's 1983 GT
408W / DNE 5 Speed / 4.10
--> 10.53 @ 129 &lt;--
<font size=-1>[ This Message was edited by: PONY1 on 1/21/04 11:38pm ]</font>
PONY1 is offline   Reply With Quote
01-21-2004, 07:00 PM   #8 (permalink)
tempercontrol
5 lug conversion
If the SN95 is the Cobra brake kit, it is very pricy. I checked on that over the summer.
Cool Progress!!!
<font size=-1>[ This Message was edited by: tempercontrol on 1/22/04 6:04am ]</font>
01-21-2004, 08:13 PM   #9 (permalink)
deleted2
5 lug conversion
[img]/phpBB/images/smiles/icon_smile.gif[/img]
01-21-2004, 09:45 PM   #10 (permalink)
1 Bad 88 GT
5 lug conversion
SN95 is the internal code for the 94-04 Mustang. The best way to go to a 4 wheel disc setup is to use the Mark VII front rotors($29/pair, not $99 like the SVO) and then use SN95(94-up Stang) rear axles, calipers, rotors, brackets and either a 93 Cobra or 94-up MC(master cylinder).
