Leaky headlights causing blown bulbs?
Likely the water is your problem, if even one drops hits the bulb when it's hot it will shatter.
Now for the water problem. The water is getting in because, the epoxy bonding the front lense to the lamp housing has cracked. When the lights are on the housing will heat up causing some air to excape through the crack. Then when it cools, air is drawn back that has some mosture in it. The mosture then condenses inside the housing
Easiest thing would be to just drill a hole to let the mosture out, but over time the humidity will attack athe silver reflectors and ruin them(yours are probably already damaged). The housing needs to be completely sealed.
You can remove the lamp assembly and put a thin coat of RTV at the seam wher the lense and housing are glued together. Then before it sets, wrap teflon tape completely around the seam. BEFORE ANYONES LAUGHS.... THIS DOES WORK!!!! Have sealed numerous Tbird and Stang lamps never anymore prob.
Unless your lenses are still crystal clear,probably the best solution is just to get new lamp housings. The difference in light output is amazing. If yours are only lightly hazed, a little rubbing compound followed by waxing will work wonders.
