01-31-2004, 04:31 PM   #1 (permalink)
SamSnyder
Anybody passing CA smog with a stroker?
Thinking about doing a 347 buildup of a 5.0 for stealth use in my '90 LX. Is anybody running a stroker and passing smog as a 5.0? If so, what combo are you using?
SamSnyder is offline   Reply With Quote
02-01-2004, 03:13 AM   #2 (permalink)
IAPEXL8R
I have a 347 motor from probe in my 1985 mustang (converted to fuelinjection a9l) with edelbrock performer heads, flat top pistons, and a .510" I .536 E lift 289 I deg 299E deg adv duration. I run a gt40 intake with 24lbs injectors And a custom chip. the car passes every time TEST ONLY. The smog guy never asks about the fuel injection (car was originally carburated). Chris
IAPEXL8R is offline   Reply With Quote
02-02-2004, 11:14 AM   #3 (permalink)
87stang
I have a 347-E from CHP also. It passed with flying colors with an all Trick Flow top end. It puts out great torque (375+ lb. ft. at the wheels/430+ at the flywheel).
I have since swapped to a Holley SysteMax intake and a custom cam...hasn't been e-tested yet.
A key thing to passing is the converters on your H-pipe...they do work. Make sure the converters are good and warm when you have the test done.
02-23-2004, 10:27 PM   #4 (permalink)
85347
My 85 carbed 347 passed with flying colors.347,E303,all smog equipt.intact.As stated make sure your cats are good.Also make sure they are hot when testing.[img]/phpBB/images/smiles/icon_smile.gif[/img]
85347 is offline   Reply With Quote
02-24-2004, 02:15 PM   #5 (permalink)
SamSnyder
How is the E303 in a 347? I have one in my 5.0 and like the idle & power, but have thought it might be a little docile in a bigger motor. I was thinking that in a 347 an F303 would be like the E303 is in my 302. Anybody have any thoughts on whether the increase in cubes also warrants a hotter cam?
02-25-2004, 10:52 AM   #6 (permalink)
87stang
Yes, the 45 extra cubic inches likes more cam. I found this out the hard way.
CHP offers cams to match their E-legal shortblocks. I think the Ford E-cams a little out-dated now, but they still work.
I'm passing emissions testing with roughly 30* duration and .540" lift. The ticket is propably the lobe speration of 114*. The car idles nice, but pulls to 6000 rpm.
Another key to passing emissions is the converters...they work.
02-26-2004, 02:19 PM   #7 (permalink)
SamSnyder
Agreed - my 90 LX with E303, GT40 heads, shorties, etc., runs cleaner out the pipes than my stock 90 LX, which I attribute to the relatively fresh BBK 2.5" converter H-pipe vs. the stock converters.
Probe Industries
