02-11-2004, 05:53 PM   #1 (permalink)
sleezyE
help me ford gurus please!
howdy i actually have 2 ques. 1. my mustang wont start after u have let it run at idle a while like when it gets 140 deg. or so. it will try to turn over once or twice but real sluggish, like a dead battery.
2. i would like a guestimate of horsepower please,
88gt 5spd mac fenderwell cold air, underdrive pulleys, motorsport alum. radiator, black magic fan,edelbrock waterpump,180 deg. therm, ford 9mm wires,msd cap & coil, mac shorty unequal headers, mac h pipe, mac pro dumps, no a/c, no air injection, base timing 12.5 adv 22.5 total, any ideas on better timing would be appreciated also
thanks to all the ford gurus
<font size=-1>[ This Message was edited by: sleezyE on 2/13/04 5:14am ]</font>
sleezyE is offline   Reply With Quote
02-11-2004, 06:22 PM   #2 (permalink)
1 Bad 88 GT
When you set the timing did you unplug the SPout connector? Cause the 22.5* total is way off.
02-11-2004, 08:17 PM   #3 (permalink)
sleezyE
yes the spout was disc. it was 10 before i moved it
02-11-2004, 08:25 PM   #4 (permalink)
sleezyE
what should base be from factory and total?
02-11-2004, 08:47 PM   #5 (permalink)
1 Bad 88 GT
OEM is 10*. You won't know what the true total is since the puter will vary it as needed.
02-13-2004, 06:38 PM   #6 (permalink)
jcassity
and im sure you did not disconnect the sprout conn while the car was running,,,,,[img]/phpBB/images/smiles/icon_frown.gif[/img] not good for tfi
jcassity is offline   Reply With Quote
02-13-2004, 07:07 PM   #7 (permalink)
1 Bad 88 GT
Unplugging the SPout is the only way to set the timing.
02-13-2004, 08:02 PM   #8 (permalink)
sleezyE
ok but what would be the answers to my original questions.
plus what do you all think the best timing would be?
02-13-2004, 08:41 PM   #9 (permalink)
1 Bad 88 GT
12-14*. Bad connection at solenoid, dead battery or bad starter. 250-260hp.
02-14-2004, 11:49 AM   #10 (permalink)
IAPEXL8R
#1 my guess is bad starter
#2 my guess is 240rwhp
Chris
IAPEXL8R is offline   Reply With Quote
