With a stock 302 cam I'd run the SO(standard output)stuff, here's why(remember were talking speed density systems here, not mass air). The EEC(computer) is programed for a certain air flow through the engine. The EEC, cam, injectors, throttle body, exaust system, etc are basically matched for optimum performance and drivability. If you use the HO EEC, intake throttlebody, and inj, but have a wimpy cam and weak exaust system you're gonna be too rich at WOT. Possibly could run a mass air setup with your stock cam, as it is measuring actual air flow.
Even the SO system should give you a noticable increase in torque and gas milage. You may be able mix the components and use a adj fuel pressure regulator, but this may cause off idle/part throttle issues. Remember I'm just reccomending what would yield the best reults. Doesn't take long for a bucking, surging engine to get old..
If you want to go HO(and get 60-70 more hp), then swap to a 351 cam with approx 210* duration on a 114-115 LCA, and have a good 2 1/4" exaust system. With these mods you'll think someone slipped a 351 under the hood. [img]/phpBB/images/smiles/icon_spin.gif[/img]
Detonation won't be a problem with a properly tuned engine, EGR is closed on WOT anyway.
1988 Turbo Coupe...5.0 Conversion... AOD... 3.73s
NA 13.11@105.32....W/90 Shot
12.23@112.19
<font size=-1>[ This Message was edited by: TurboCoupe50 on 2/24/04 6:10am ]</font>
