03-24-2004, 01:27 PM   #1 (permalink)
bigpres20012001
Replacing a clutch
I am replacing my clutch in a 01 stang 3.8 v6. I replaced the pilot bearing, clutch disk, pressure plate, and throw out bearing. When I try to bolt the tranny to the bell housing, I can't get it to go all the way in. There's about a 1/4 to a 1/3 of a inch gap between the tranny and the bell. Does anybody have any ideas of what the problem is? I have already double checked to make sure that the pilot bearing was in far enough. I can't think of any thing else.[img]/phpBB/images/smiles/icon_cry.gif[/img]
bigpres20012001 is offline   Reply With Quote
04-27-2004, 09:43 PM   #2 (permalink)
erics392
Replacing a clutch
is your clutch disc facing the right way? sometimes the
pilot bearings are snug. you need to have a perfect alignment to get them in. If your close you should be able
to pull it in with the bolts...E
erics392 is offline   Reply With Quote
