Crane Gold Roller Rockers
Hello everyone. I need your professional advice. I am building a 306. The parts I've used so far are listed below. I just purchased a set of Crane Gold Roller Rockers (1.6) to install on a set of AFR 165 heads milled to 54cc with the upgraded spring package. I am considering stepping up to the 1.7 crane rockers, which will require me to change the rocker studs to 7/16" from 3/8". The total cost of the upgrade would be $120, including the rocker arm studs. The cam I have is the lunati P/N 51014, 218 (.500) intake, 226 (510)exhaust with 1.6 rockers. If I step up to the 1.7 rockers the cam would be 218 (.530) intake, 226 (.542) exhaust. The car will be a street car that won't see more than 6000 rpms. Is it worth spending the $120 on the upgrades or should I use that money for other performance parts? Also, if I use the 1.7 roller rockers what type of performance gain should I expect, if any, and will it affect the rpm range of the car. Thanks for anyone's help and opinion.
Stock crank
eagle rods
probe pistons
AFR 165s milled to 54ccs and upgraded springs and valves
ARP bolts (main, rods etc.)
Crane gold roller rockers
crane lifters
lunati cam P/N 51014
Block bored .030
FRPP oil pump
FRPP dual roller timing chain
stock distributor
