05-02-2004, 04:41 PM   #1 (permalink)
etcetera
86 suggestions
I've got a really low mile 86 HO. I'm guessing less than 30k. All tolerances are well within specs. It's out of the car, on a stand. I'm keeping the EFI.
Are there any good heads that will bolt on with the flat top pistons?
I was thinking maybe the twisted wedge heads would fit. Along with an eftermarket intake. Motorsport cam with a lope.
The engine's going in a 65 ford econoline with a finished weight around 2500lbs and a beefed up AOD. I'll probably run 3.9o's or so in the factory 9 inch. I have long tube headers specifically for the 302/econoline swap. Exhaust will be about a 3 foot run dumping in front of the rear tires.
Any suggestions to make some good HP. I'd love to be over 300hp. I don't mind running mid grade or premium, it's not a daily driver.
Eric
<font size=-1>[ This Message was edited by: etcetera on 5/3/04 4:06am ]</font>
etcetera is offline   Reply With Quote
05-03-2004, 09:45 PM   #2 (permalink)
1 Bad 88 GT
86 suggestions
Save yourself the aggravation and just drop in some new pistons/rings. You won't be able to run any worth while cam with the FT pistons.
05-03-2004, 10:25 PM   #3 (permalink)
etcetera
86 suggestions
Thanks for the suggestion.
The factory hone marks are visible all the way around each cylinder. I'm sure the motor wasn't touched before I opened it up. I've done a bunch of complete rebuilds with overbore, but never a refresh. Should I hone the cylinders, or just put the new pistons/rings in?
How do you guys like the GT-40 Y303 heads? Price is right....
Eric
05-04-2004, 07:22 AM   #4 (permalink)
1 Bad 88 GT
86 suggestions
Y303's are OK just not as commonly used as the X303's.
05-07-2004, 04:02 PM   #5 (permalink)
gorgan1314
86 suggestions
for my 86 I bought KB performance pistons (KB115) and childs and albert moly rings for about $245 including shipping from United Engine and Machine co. I'd just bore .30 over and save yourself the headache, than you can use whatever head you want. I think the valve reliefs on the 115 is up to 2.10.
gorgan1314 is offline   Reply With Quote
05-08-2004, 01:35 AM   #6 (permalink)
TurboCoupe50
86 suggestions
I run the Twisted Wedges on a stock '86 short block using the Trick Flow Stage-1 cam. I've been very happy with it, all the cam I'd ever want(My Bird is mostly a street car). Its enough cam that you'll have a nice little lope.
1988 Turbo Coupe...5.0 Conversion... AOD... 3.73s
NA 13.11 @ 105.32....W/90 Shot 12.23 @ 112.19
<font size=-1>[ This Message was edited by: TurboCoupe50 on 5/8/04 12:44pm ]</font>
TurboCoupe50 is offline   Reply With Quote
05-08-2004, 03:38 PM   #7 (permalink)
etcetera
86 suggestions
I've got the twisted wedge heads now. Lot's of clearance there with stock pistons. I called trick flow, and they said I should be able to run .540 lift with stock pistons, I measured with clay and the stock cam, and I think I could safely run even more than that. maybe .550 or .560. Doesn't matter, I'll be running around .500 or so.
Eric
La Habra, CA
05-10-2004, 02:36 PM   #8 (permalink)
2FST4U
86 suggestions
Dunno if you guys read it or not, but Car Craft took a stock 5.0 shortblock and did a nice build [img]/phpBB/images/smiles/icon_biggrin.gif[/img]
Let me quote the second paragraph:
"The key to this remarkable achievement is simple: one awesome set of cylinder heads. Heads so good in fact, that there are worth about 100hp over a set of stock 5.0L Mustang heads on their own."
100 hp for under $1400.
Here's what they used:
stock '91 5.0L short block
AFR 165 heads PN 1472 from AFR for $1325
Comp Cams 1.7:1 roller rockers PN 1054-16 from Jeg's for $378.99
Arp head bolts $37.99
Fel-Pro head and intake gaskets $81.97
Weiand intake manifold $165.99
Road Demon Jr. Carb $259.95
and Doug's Tri-Y headers for $549.95
So 405 hp at 6,200 and 380 ft-lbs at 4,300 doesn't sound too bad for $2,799.84? All on the best cam IMO for driveability - the stock Ford HO
[img]/phpBB/images/smiles/icon_tup.gif[/img] And don't quote me on this, but with a stock cam the AFR heads may not give you any P/V clearance issues.
2FST4U is offline   Reply With Quote
