06-24-2004, 06:59 AM   #1 (permalink)
giddyup1
what manifold
You guys running 347's, what manifold,size throttle body,size injectors are you running?
giddyup1 is offline   Reply With Quote
06-24-2004, 09:40 PM   #2 (permalink)
tonys10sec306
what manifold
i would use either the trick flow track heat intake or a holley systemax intake.a 70mm throttle body and 24 or 30 injectors will work good with a 347
06-25-2004, 12:19 AM   #3 (permalink)
allen
what manifold
we just installed the trick flow R series on my buddies 347 and the car seems to have all kinds of power. the holley or trick flow track or R series would seem to be good choices.
allen is offline   Reply With Quote
06-25-2004, 12:23 AM   #4 (permalink)
allen
what manifold
oh, he is also running a 70mm t.b., 75mm mass air, and 30 pound injectors, hope this helps.
06-25-2004, 04:58 AM   #5 (permalink)
giddyup1
what manifold
Allen......what heads,comp ratio,ecu and cam is your mate running?
06-27-2004, 04:23 PM   #6 (permalink)
allen
what manifold
he is running trick flow box stock heads, 9.5 to 1 compression ratio, stock computer, and a e-series cam.
