06-30-2004, 09:47 PM   #1 (permalink)
johnny460
power windows
Hi all
I have a '89 mustang that both windows go down but not up.
I checked the power at the switches and have power to the down side but no power to the up side of the switch. Any ideas?
As always, thanks much
Johnny
johnny460 is offline   Reply With Quote
07-05-2004, 12:54 PM   #2 (permalink)
CaptVirgilHilts
power windows
I have had an '88 and an '87 with power windows and have found for the most part the contacts in the switches are to blame for this problem. The good news is they can be dismantled and cleaned with fine emory cloth and or an emory stick etc. The switches themselves plug in as modular units into the arm rest frame. They are then held together with barbed clips on their plastic casings. Simply use a small screwdriver and CAREFULLY disassemble them and clean the contact points. Reassemble and see how they work. If all else fails they can be swapped out with a known good used set very easily. Good Luck, Stu [img]/phpBB/images/smiles/icon_tup.gif[/img]
07-27-2004, 08:37 AM   #3 (permalink)
alexauto
power windows
second that... the switches are notorious for corrosion. i'd be hunting ebay for a replacement as they are usually only a couple of bucks..
alexauto is offline   Reply With Quote
