07-21-2004, 05:17 PM   #1 (permalink)
fordcoupe89
stud girdle
i would like some input on stud girdles pro and cons
i am building the 400hp302 on this site do you think i should put a girdle on the motor or not give me your reason
for your choice
fordcoupe89 is offline   Reply With Quote
07-21-2004, 11:36 PM   #2 (permalink)
tonys10sec306
stud girdle
If you are turn 7000 + rpms and using a mech flat or mech roller. i would use one.they will help keep your valve lash longer.
08-03-2004, 07:16 AM   #3 (permalink)
pistoncrazy
stud girdle
I would recomend a stud girdle if you are running 2-bolt block, but do make sure that your crank tunnel has been line bored with all intended hardware in place and tensioned to manufactures specs( stud kit, girdle)because the tunnel will distort and you will possibly lose your main bearing oil clearance.If possible line bore with cylinder torque plates also in place to receive true clearances.Use a good quality girdle and be sure to check that your rods and oil pump dont fowl on the girdle.
pistoncrazy is offline   Reply With Quote
08-03-2004, 07:47 AM   #4 (permalink)
fordcoupe89
stud girdle
i would have my machine shop follow those guide lines but it was way to much up here to have it done so i ordered a
dss pro bullet with stud girdle,i have run one of there motors in the past with good results i really wanted to build my own bottem end but i guess it has got to the point that you are better off ordering a short block,besides
most machine shops get nervese when i talk about spraying a motor dss doesn't bat an eye
