1996 mustang gt clicking noise
maybe its your timing. Do you know if the previous owner changed the timing? If so then the ping that you hear might be detonation. To fix that all you gotta do is get a timing gun and set your timing to 0. Also if you hear a whining noise coming from the starter, it probably means that the teeth are worn and slipping. There are plenty of aftermarket starters to replace your worn starter. Another few things you could check are the valves (make sure they clear), your clutch (might have to re adjust / replace it). It could also be as simple as tightening your clutch cable cover (mine made a clicking sound when it was in gear because it was too loose). Thats all I could think of for now. hope it helped
____________________________________________
87 fox body GT - 351w, gt40 manifold, custom upper, solid lifters, flat tappet cam, 225lph fuel pump, aluminum flywheel, underdrive pulley's, cold air intake, mass air, 24# injectors, Estimated 300 rwhp *AFR 225s comings soon!*
