09-19-2004, 02:10 PM   #1 (permalink)
paffett
How to plug cylinder smog fitting?
Have scraped the smog pump. What is the thread pattern on the rear of my 87 5.0L where the air inlet piping used to be. 5/16ths? Help me plug this safely. Thanks
paffett is offline   Reply With Quote
09-19-2004, 08:02 PM   #2 (permalink)
BobsSleeper
The Ford vender that travels to most of the Ford events sells the plugs that you are looking for[img]/phpBB/images/smiles/icon_wink.gif[/img]I had a set from him,but sent them back when I got my GT40P heads.
Rahe Racing
1649 S.O.M. Center rd
Mayfield Hits,Ohio 44124
(440)646-1957
nights and weekends
Jahn Rahe
Hope this will help you[img]/phpBB/images/smiles/icon_spongebob.gif[/img]
BobsSleeper is offline   Reply With Quote
11-04-2004, 09:08 PM   #3 (permalink)
Nosboss
I have used 5/8 bolts with loctite on the threads to plug the smog holes.[img]/phpBB/images/smiles/icon_tup.gif[/img]
Nosboss is offline   Reply With Quote
11-05-2004, 06:28 PM   #4 (permalink)
primrisfastr50
the first time i did it on my 89 i simply hacked of the tubing from the metal ends flipped them around so the flush metal faced the head and bolted them back on with the little bolts, didnt even use any silicone or anything, plugged it right up, ford sells the correct plug though, its double threaded inside and out, forgot the part number, good luck
primrisfastr50 is offline   Reply With Quote
11-05-2004, 07:04 PM   #5 (permalink)
gork1rogues
For the rear you can use a short 13/16" headed bolt.
11-09-2004, 02:14 PM   #6 (permalink)
IAPEXL8R
your local ford dealer should have the correct plugs. chris
IAPEXL8R is offline   Reply With Quote
11-21-2004, 12:12 PM   #7 (permalink)
C7Z
The Ford part number for those cylinder head inserts is :
F4ZZ-6E086-A
They come in a package of 2 and I think they cost around $10
C7Z is offline   Reply With Quote
11-26-2004, 03:35 PM   #8 (permalink)
Late91GT
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>the first time i did it on my 89 i simply hacked of the tubing from the metal ends flipped them around so the flush metal faced the head and bolted them back on with the little bolts, didnt even use any silicone or anything, plugged it right up,</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
I have used this method also many times, and it works well! Also I have seen other people use spark plugs to plug them. Basically it all depens on how much your pluggin. If the inserts are still in place then a bolt thread will plug it, if not and the whole insert comes out, then it will be a pipe thread If I remember correctly.........If it were me I'd do what "prim" and I have done and use the existing pieces with the tube cut off and (what I did was) actually weld the tube together!
good luck
Ben
Late91GT is offline   Reply With Quote
12-06-2004, 02:26 AM   #9 (permalink)
matt17
i went to advance auto and got 2 small freeze plugs and used a lil loctite!
matt17 is offline   Reply With Quote
Probe Industries
