Fuel pump run on on a 1988 F250 460
For sure it's a sticking relay. (fuel pump relay). Both of them should be mounted on a slim metal holder gig on the drivers side inner fender. (pretty much directly over the tire).
Common concern/problem. Usually tho someone's disconnected the relays, and they're laying upside down, (where they collect water/crap, and corrode/go to hell fast).
Cheap repair tho, if it's just the relay. Under ten bucks if I remember right.
In either case, good luck, have fun.
(while you're there, ya might as well replace the PCM relay too). CYA.
