swap of efi bronco upper manifold to mustang upper manifold ?
If you take a look at the aftermarket...you may notice that the Truck EFI base was the inspiration for several high performance 302 manifolds. Specifically the Holley System Max and Saleen manifolds and deriviatives. It actually offers more flow the many of the accepted front runners. So if you are looking for maximum air flow, you may want to keep the truck manifold for later.
But to answer your question...you can swap the passenger efi intake for the truck intake, it's a bolt-on. Just be sure to swap everything. As far a computer, wiring, sensor inputs, conversion to Mass air...etc. These might be issue you want to address - before going too far into the project.
I really hate to see people get into a project that it technically outside their skill set...not that yours is a case like that. I mention it as a general warning that just because something can be done, it doesn't necssarily follow that it is easily done.
<font size=-1>[ This Message was edited by: Beoweolf on 7/26/05 6:55am ]</font>
