Ok guys need some expert troubleshooting advice of my 92 Mustang.. Here the situation, 2 weeks ago Saturday I took my mustang out.. No problems ran great... Next day took it out and it had a slight hesitation and if I gave it gas over 3k RPM's I get a poping out the intake like a backfire... So i cleared my codes in the computer drove the car and got code 13,19 and 85. I know what code 85 is, thats the carbon canister. 13 and 19 are idle issues. First thing I thought of was the idle speed sensor on the throttle body, I replaced that with no luck BUT that did clear up code 19, I checked for vacuum leaks, I didnt find any. So right now I get code 13 and 85 from my computer test. Im not trying to go out and spend $300 on a bunch of new stuff that isnt going to fix my problem.. Does anyone have any suggestions or may have run into this issue... So far Ive been told it could be a number of things.. Plugs, Wires, Coil, Fuel Pump, Fuel Regulator, Sensor on distributor... Would bad O2 Sensors cause this? Anything would be appreciated..
Something I forgot to mention, check engine light does come on when its poping out the intake..... Though since ive owned the car 3 years now in cooler weather the check engine light would pop on from time to time when cruising down the road but if never effected it running...
- Kurt
64 Falcon
92 Mustang
03 Silverado Z71
<font size=-1>[ This Message was edited by: bud168 on 10/14/05 5:33pm ]</font>
