New engine in 91 GT with serious tuning problems
I need some help with this one. My engine is .30 over roller block with AFR heads 185cc 58cc. It has Silverlite pistons 10:1 compression. Lunati cam adv duration 285 int, 291 ex, dur. @50 221 int, 232 ex., gross valve lift 526 int. 530 ex. and a 106 lobe seperation angle. It has the GT 40 intake, 65 mm throttle body, 76mm mass air w/24 lb injectors w/ 24 lb sample tube., it has 3:55 gears, 5 speed tranny. Shorty equal length headers with H pipe and flowmaster mufflers. NO converters. Engine will not idle and no power till over 3000 rpms. Timing is set at 12 degrees static 32 total. Also cannot start at all or with difficulty after engine is hot. I was trying to get it close so I could drive it 70 miles away to a dyno shop but presently not driveable. Any assistance would be appreciated.
