Yet another surging Idle problem...
Your IAC(idle air control valve) may still be flowing too much air when the duty cycle increases.
Has the idle ever been slow to return after you rev it?
If you have a manual trans., do the RMP's hang between shifts?
If so you may have too much air flowing through the IAC.
Try this...next time it surges, unplug the IAC and see if the RPM's drop. If they do, you may need a IAC restrictor plate to even the idle out.
Good Luck, Chris.
