01-21-2007, 04:44 PM   #1 (permalink)
Falconinpa
4.6 mass air
I learned that 03 Police Interceptors have 80mm mass air meters. I also learned that 97-98 Mk VIII's have them too. Does anyone know if i can swap a MK VIII 80mm mass air meter into a 2000 Police Interceptor Crown Vic (4.6)? Will it work, and play nice with the computer? Anything else I would have to change with it (injectors ect.)? I know a k&n would be needed. Thanks.
Falconinpa is offline   Reply With Quote
10-04-2007, 07:14 PM   #2 (permalink)
cdjnight
Re: 4.6 mass air
there's no need to get a bigger meter unless you are exceeding the 375-400hp range.
Momentum is everything, until you drive off a cliff!
cdjnight is offline   Reply With Quote
10-04-2007, 07:16 PM   #3 (permalink)
bassman97
Re: 4.6 mass air
If the injectors are the same for both cars, then yes, you can swap w/ no problems.
10-05-2007, 11:57 AM   #4 (permalink)
vristang
Re: 4.6 mass air
Sorry, but there is a 99.99999% chance that this is wrong.
A Ford MAF meter is setup for a very specific ECU. The injector settings are separate.
To know if it will work, you would have to compare the MAF Transfer of each application.
If the Transfers are within about 10%, then you could try it and it should work pretty well.
Ford didn't make many MAF meters that were interchangeable though...
jason
vristang is offline   Reply With Quote
