Camshaft recommendations...
If you have stock un-ported GT40 heads, you will not make much more power then stock, no matter how much lift you put on a cam. The 1.7 rockers will only add stress to your valve train, and you will loose low end torque.
Sorry, but the GT40 heads are barly better then stock. You can put 50 - 70 hours of porting work in them and get more power, but cam/rocker changes alone will not gain you much.
