06-09-2007, 06:18 PM   #1 (permalink)
mas942
Adjusting hydraulic lifters in an 89\' 5.0
My son and I are back to work on our 5.0 ranger swap.
Just put a new set of stock ford lifters, rockers , a HO cam and timing chain set in a stock 89' 5.0 from a lincoln.
I beleave we just torque the lifters to 22 lbs is that correct?
Thanks Mike Sr[img]/forums/images/smiles/icon_confused.gif[/img]
mas942 is offline   Reply With Quote
06-09-2007, 07:47 PM   #2 (permalink)
89Trooper
You mean torque the rockers? [img]/forums/images/smiles/icon_smile.gif[/img]
So you have the pedestal mount rockers. They do make shims to adjust them if needed, but I would always make sure the lifter was not on the lobe of the cam for the rocker I was installing, and then I would just torque them down. Never had any problems.
This was when everything I was using was stock. When heads and stuff start changing, I would go to adjustable stud mount rockers so you can pre-load the lifters properly.
89Trooper is offline   Reply With Quote
06-10-2007, 05:12 AM   #3 (permalink)
mas942
Thanks,
Yes torque the rockers.
We're just cleaning up this stock motor to get the truck put together with a C-4 trans once all the bugs are out of us and the truck than we'll start building a real motor for it.
Thanks Again Mike Sr
