07-08-2007, 06:47 AM   #1 (permalink)
wildosvt01
Did the 4cyl to V8 swap, But it wont start with the key
87 Notch with 89 engine and wire harness. It does run with a momentary switch temporarily installed on the solenoid for starting.
I recall reading about a jumper under the dash that needs to be pluged or something? I just cannot find the topic! The clutch saftey switch (best way to describe it, Im tired from 3 days of serious wrenching) is not plugged in. The car was an automatic car before the T-5 went in. I do not yet have the wire harness for the reverse lights that plugs into the T-5.
Do I need to splice anything under the car where the plugs for the nuetral saftey was on the auto trans?
Anyone?
Thanks in advance,
Wildo
Wildo
1965 Galaxie Fastback-351C 2v/C4 with a 3.50 Trac-Loc
2007 Torch Red Shelby GT500
2004 Marauder/2004 Cobra
[b]Out of a job yet? Keep buying foreign!![/b]
07-08-2007, 07:55 AM   #2 (permalink)
gbic1
Re: Did the 4cyl to V8 swap, But it wont start with the key
If you switched the whole harness you need to hook up the clutch safety switch or jump across it. Originally the power went to neutral safety switch on transmission.
] 20 years Ford Dealer Master tech.
07-08-2007, 08:31 AM   #3 (permalink)
gotyurback
Like gbic1 said, if its an Ford harness you have to connect the NSS or jump the terminal.
1969 Ranchero 500 351W
1963 1/2 Galaxie 500 XL 390FE
1964 Comet Caliente 347 EFI
1967 Mustang 289
gotyurback is offline   Reply With Quote
07-08-2007, 04:13 PM   #4 (permalink)
wildosvt01
I got it all squared away. I kicked back outside in the breeze with the trusty Chilton's and I've got her all set. Reverse lights and starter both work.
I ended up jumping it for now. I will do some more investigating and try and get the harness for the clutch switch.
Thanks ALL!
Wildo
swap a 4cyl for a 5.0 302musclehead Mustang Pages (1979-1995) 3 05-04-2006 03:26 AM
IT WONT START fender2k5 All Ford Techboard 3 06-01-2005 10:10 PM
car wont start 65stang289 All Ford Techboard 3 06-07-2004 08:51 AM
help,this 302 just wont start steharz All Ford Techboard 2 05-12-2003 10:20 PM
'88 Fox 4cyl / V8 Swap Cobra77 All Ford Techboard 11 01-19-2002 05:51 PM
