08-03-2007, 05:53 PM   #1 (permalink)
jrosengarth
MAF Conversion EEC Pin 43 Conflict...HELP!!!
I have a 93 F-150 that I have replaced the computer with an A9P for a MAF conversion, and while repinning the PCM harness I found pin 43 occupied (L HEGO on the A9P). My wiring diagrams for the old computer say this pin is spliced to the wire going from the A/C pressure switch to the A/C blower switch. Sounds to me like it's just a way for the computer to tell if the A/C compressor is running when switched on, right? My question is: what do I do with this wire? Can I just pull it and leave it hanging, or does this belong in another pin position on the new computer? I do not have the EVTM for the A9P (92 Mustang GT). Any help would be most appreciated!
-J
http://www.concentricsoft.com/Personal/Jim/Truck/TruckRebuild420(sig).jpg
F150 Rebuild Project Website
jrosengarth is offline   Reply With Quote
08-05-2007, 06:57 AM   #2 (permalink)
Joel50
Re: MAF Conversion EEC Pin 43 Conflict...HELP!!!
Yep....that's the A/C Demand signal in a 4.9L ECM....you could remove it and leave it disconnected, it's not used in the A9P as you see here .
Joel50 is offline   Reply With Quote
08-06-2007, 11:30 AM   #3 (permalink)
jrosengarth
That's what I'll do then. Thanks!
-J
Need help with 2 to 4 bbl conversion!! DesertGalaxie Galaxie Pages 22 02-16-2005 12:10 AM
AVS to AFB conversion: Possible? SteeLDawN All Ford Techboard 0 09-22-2002 12:58 PM
FMX TO C4 CONVERSION 69muzzy All Ford Techboard 2 08-05-2002 07:03 AM
AOD Conversion trimmer All Ford Techboard 1 05-13-2002 01:06 PM
T5 to C4 Conversion wild4stangs All Ford Techboard 0 04-29-2002 09:42 AM
