08-03-2007, 08:25 PM   #1 (permalink)
63Unibody
limited to @ 50 MPH road speed
I am knew here but I am hoping that you can assist me with a problem that I am having.
The problem is that the truck is limited to @ 50 MPH road speed. It acts like it has a governor. It is not a fuel problem, for sure. And it is not RPM related, since I can downshift and still not change the spot where it cuts out.
Here is what I have; It is a 1996 F 150 5.0 with the 4R70W transmission. The drivetrain has only 16K original miles on it. I transplanted the drivetrain and all of the related parts into a 1963 Unibody pickup. I used all of the wiring, computer, etc. I also have an electronic instrument cluster to match. The only change from original that I had to do was that I wired a VSS into the output shaft of the transmission since I could not use the ABS system.
I sure hope I gave you enough info, as this thing has me pulling my hair out. Everything works great up to 50MPH.
Tim
63Unibody is offline   Reply With Quote
08-03-2007, 11:49 PM   #2 (permalink)
Re: limited to @ 50 MPH road speed
Computer issues bro.
08-04-2007, 04:39 PM   #3 (permalink)
MarksM
It sounds like you are bumping the factory speed limiter somehow. I would guess it has to do with that vss on the driveshaft. The only way I know to remove the limiter is to have the EEC reflashed or get a chip for it.
1995 Thunderbird Supercoupe, 5-speed (1of 574 produced)
1972 Gran Torino Squire wagon
1973 Ranchero Squire
2006 Mazda MX5 sport
MarksM is offline   Reply With Quote
08-04-2007, 05:58 PM   #4 (permalink)
dbu8554
maybe safe mode?
Cleveland powered limited production car????? retyler The Garage 3 11-02-2006 08:41 PM
anyone using a Limited Slip Diff.? jeff63390 Galaxie Pages 3 01-08-2004 03:52 PM
Limited Slip 8" AZ65coupe All Ford Techboard 6 08-11-2002 04:15 PM
What's the difference between Posi and Limited Slip thecougarguy All Ford Techboard 2 05-24-2002 03:59 AM
Open track road racing @ buttonwillow Do you crave speed??? IAPEXL8R Event Calendar 3 01-26-2002 03:10 AM
