02-14-2008, 11:40 PM   #1 (permalink)
darkhorse50
explorer heads
Decided to go with explorer intake and head swap. I plan on running the gt40 explorer heads(95-97.5) versions. From what I have gathered the compression ratio of my car will drop with these heads???.... Im pretty sure a stock 5.0 runs 9:0:1 compression. So how far do I have to mill these heads to bring my compression to say 9:5:1, and in doing so will I have to have my pushrods shortened/and or have my valves shortened to compensate for the heads being milled?
Any insight will be greatly appreciated
darkhorse50 is offline   Reply With Quote
02-17-2008, 12:45 PM   #2 (permalink)
notched306
Re: explorer heads
i just posted this in another topic.should awnser your ?'s
http://www.fordmuscle.com/forums/lat...d-rebuild.html
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
02-20-2008, 07:47 PM   #3 (permalink)
darkhorse50
Re: explorer heads
no one knows what the compression would be on these heads and how far they have to be milled to acheive a 9:5:1 compression?
02-21-2008, 08:34 PM   #4 (permalink)
anthonydalrymple
Re: explorer heads
Go here: www.tmossporting.com
Allot of good info if you take the time to look it all over IMHO.....
anthonydalrymple is offline   Reply With Quote
03-08-2008, 01:03 PM   #5 (permalink)
Pegleg302
Re: explorer heads
Hi, if you c.c. the combustion chamber of the original 9 to 1 head, say 62 cc for instance, then find out the c.c. of the explorer head. If you have to remove too much, you will have more trouble than pushrod length, also having to worry about weather your intake manifold will fit, as milling will lower the intake ports in relation to the block/ manifold sealing area.
Pegleg302 is offline   Reply With Quote
GT40 heads off of 96 explorer...how much lift will they take? dablack All Ford Techboard 8 02-01-2006 11:27 AM
explorer 5.0 gtp heads into speed density car tayloredfabrications Late Model EFI Techboard 2 08-26-2005 05:50 PM
explorer heads and intake sleezyE All Ford Techboard 8 06-01-2005 12:41 PM
99 Explorer engine (302) with GT40P heads ALLTIRE All Ford Techboard 4 06-29-2004 07:52 AM
info on gt-40p heads off a ford explorer? blwiii Late Model EFI Techboard 1 02-02-2004 09:55 PM
Holley
