02-15-2008, 12:16 AM   #1 (permalink)
darkhorse50
head rebuild ?
Like I said before I plan an putting a set of explorer gt40 heads on my car. These heads are going to be high mileage heads. With money as an issue what absolutely has to be done to these heads, to insure there performance. I know valve springs and lifters are a must, but besides that do I really need to get a 3 or whatever angle valve job done? or anything for that matter. Oh and other then me gasket matching the heads, what else can i do to sqeeze a couple extra hp out of them.
darkhorse50 is offline   Reply With Quote
02-15-2008, 05:01 AM   #2 (permalink)
KULTULZ
Re: head rebuild ?
It all depends on what they are going on and how fast you want to go.
Read this- http://www.fordmuscle.com/forums/sea...searchid=81281
[FONT=Century Gothic][/FONT]
02-15-2008, 05:39 AM   #3 (permalink)
darkhorse50
Re: head rebuild ?
My budget is pretty tight, I'm a broke college kid so the cheaper the better. I dont wana just throw the heads right on the car, that would just be stupid on my part, but at the same time I dont wana a $500 machine shop bill. So a nice happy medium I guess
02-15-2008, 05:49 AM   #4 (permalink)
KULTULZ
Re: head rebuild ?
I would do as mentioned in the other post, check that the valve seats are in good shape by the same method. If so, lap the valves, check guide clearances, seals and new springs. Three angle is not absolutely neccessary.
02-15-2008, 06:03 AM   #5 (permalink)
darkhorse50
Re: head rebuild ?
Thank you for the insight, and by the way that post didnt work for me
02-15-2008, 06:08 AM   #6 (permalink)
GaryWhite7
Re: head rebuild ?
Link doesn't work.
GaryWhite7 is offline   Reply With Quote
02-15-2008, 06:14 AM   #7 (permalink)
KULTULZ
Re: head rebuild ?
Originally Posted by GaryWhite7 View Post
Link doesn't work.
This appears to not be my day... sheesh...
http://www.fordmuscle.com/forums/all...ed-valves.html
02-17-2008, 12:43 PM   #8 (permalink)
notched306
Re: head rebuild ?
a few things,the explore heads are the gt40p heads.the sprak plug angle is alittle more that the e7 heads.you might be able to use your stock headers,if not you have to get hte ones for the "p" heads.reason being is that the spark plugs might hit the header flange of the stock ones.another thing is running the stock mustang rockers will not work unless you get a longer push rod.the rocker bosses are higher than the e7 heads or you can go adjustable and be good with those.you also have to run a spark plug from a explore.i got them for a 98.all this stuff i already went through.
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
Edlebrock head bolt bushings on stock head wildosvt01 All Ford Techboard 5 05-18-2007 03:18 PM
What kind of head gaskets and head bolts should I buy ? BobsSleeper All Ford Techboard 4 06-06-2005 07:58 PM
New and going to ask for opinion right off the bat - To rebuild or not to rebuild KristensRanchero The Garage 27 07-14-2004 01:31 AM
aluminum head rebuild qtrhors All Ford Techboard 2 06-25-2004 02:12 PM
Head Swap/Trans Rebuild ... 466mav All Ford Techboard 1 09-12-2003 02:50 AM
