03-10-2008, 01:31 PM   #1 (permalink)
elsanyo
dead injectors
first I want to appoligise for bringing this up. Ihave a 1990 festeva in my shop that hasn't been ran in 10 years.Let it be known that others have tried to get it to run .So I found a few prob's with it and replaced them such as a fuel pump and screen a fuel regulator fuel filter ,plugs ,wires , airfilter ect.But my problem is Ibelieve is that I don't have 12 volts going to the injectors,my noid light does not come on .Can anyone tell me if the injectors have a fuse,or relay somewhere and if so where in world is it
elsanyo is offline   Reply With Quote
03-10-2008, 07:48 PM   #2 (permalink)
Re: dead injectors
I don't think the 90 festiva has a fuse for the injectors...
The ECM sends the power to the injectiors....
Check BOTH wires to the injectors with the key ON. Set the noid light aside and just check for voltage to them with a 12V test light or a volt meter.
You should have power there with the key on.
If not there is likely acomputer issue I think...
FE
03-11-2008, 03:28 PM   #3 (permalink)
elsanyo
Re: dead injectors
thanks fe,this thing hasn't ran in 10 years it still has a full tank of gas which i have to remove.It will start and run on some starting fluid
03-11-2008, 06:01 PM   #4 (permalink)
Re: dead injectors
Remove and Clean the Injectors... That'll let her fire
03-13-2008, 06:55 PM   #5 (permalink)
Bluemr24
Re: dead injectors
Gary, I sday it every time, you're a friggin' Genius!
MikeR
Bluemr24 is offline   Reply With Quote
03-13-2008, 10:55 PM   #6 (permalink)
Re: dead injectors
Awwwwe shucks....
You're just too kind...
Well, did cleaning the injectors do anything or are they missing...
03-17-2008, 04:53 PM   #7 (permalink)
elsanyo
Re: dead injectors
ok its an update, removed fuel rail and injectors .....cleaned thurolly and reinstalled ,drained fuel and replaced with seafoam and hightest BAM its alive thanks again FE
03-17-2008, 08:05 PM   #8 (permalink)
Re: dead injectors
AWESOME! Glad to help!
04-05-2008, 08:28 PM   #9 (permalink)
Bluemr24
Re: dead injectors
I'll try to say it again, Gary, you're a friggin' Genius!
MikeR
04-05-2008, 10:42 PM   #10 (permalink)
Re: dead injectors
STOP TEASING MIKE! I'm nearly in tears here... The guy's a bit slow and I told him what to do and he got all mushy on me, adn I accepted teh praise graciously... But ANYONE could have told him that... They just didn't...
30# injectors DominickSch The Garage 8 04-24-2007 08:51 AM
injectors and MAF litlegto Mustang Pages (1979-1995) 5 07-31-2006 02:48 PM
can i use 19# injectors?? saleenstang88 Mustang Pages (1979-1995) 1 08-28-2005 07:52 PM
19# injectors... 91gt All Ford Techboard 1 04-27-2004 01:37 PM
87 5.0 INJECTORS DEANO All Ford Techboard 1 03-18-2002 09:45 PM
