06-01-2008, 05:22 AM   #91 (permalink)
flocko
Re: Idle problem AGAIN!! NO WAY?
Thanks for"the detail"!!! I am currently at 43psi on 19# injectors(set with vac unhooked). I`m not looking a "gift horse in the mouth" BBBUUUUUTTTT, This engine has run at 43psi for four year and all of a sudden, out of the blue , it`s not enough fuel???? I`m a logical type of guy so I have to ask some questions here. Will 19# injectors handle more pressure. Pressure is pressure not nessarily more fuel. If you take a gallon of liquid and put say 40 # of pressure to it then put 50# of pressure to it you still have a gallon of liquid. Wish I had an A/F ratio gauge. To damn expensive. Would love to do wide band monitoring. What would you sugest as a good incremental point. One or two psi at a time until it goes rich then back it off a little. How much is to much psi for stock injectors and lastly, THANKS JOEL, YOU REALLY HUNG IN THERE AND HAD THE TEMPER TO DEAL WITH ME. I HAVE LEARNED MORE IN TWO WEEKS FROM YOU THAN IN FIVE YEARS FROM ANY ONE OR PLACE. I joined another forum as a way to maybe see the more technical side of how these efi cars "tick". See you on the flip side!!!
flocko is offline   Reply With Quote
06-01-2008, 06:00 AM   #92 (permalink)
flocko
I have a set of used , E-bay specials. 24# injectors. Would need to change sample tube. I was gonna wait until I upgraded the intake, heads and exhaust. I also have a Ford 190ltr. fuel pump, brand new still in the box. What u think? Just thinkin out loud. Plan on doing ur perscription first but also thinking "what if "
06-01-2008, 06:25 AM   #93 (permalink)
Joel50
The stock FP specification is 30-45 psi engine running vacuum connected. Having an O2 code present means the corrections the system does to the fuel trim are outside its ±12.5% capability to increase/decrease the injectors fuel pulse width (FPW)....... a good starting point would be 39-40 psi vacuum line connected...... if the EEC can control A/F within that pressure (= O2 codes not showing in a KOER), let the EEC do its work.... if the lean codes show up at that point, raise FP to 42 psi and recheck.
Fuel pressure is not a tuning parameter, the EEC will auto compensate for any variance of that non-EEC controlled parameter based on the feedback from the O2s (in close loop) + learn through the adaptive strategy to add the required offset fuel trim to prevent over compensating for it during open loop operation by changing the base fuel/spark tables. Since the open loop base tables get an A/F "adder or reducer", the learned fuel trim is applied for all open loop conditions (cold start up, warm up and WOT).
In your case, it's a matter of providing the correct FP so the EEC fuel trim corrections fall within its ±12.5% capability window, and not have the A/F failure codes.
Joel50 is offline   Reply With Quote
06-01-2008, 08:18 AM   #94 (permalink)
flocko
I`m gonna have to "soak" on that for a while but I think ur saying that i am out of range of correction factor therefore 41/91.
06-01-2008, 09:11 AM   #95 (permalink)
flocko
Ran car to temp with FPR plugged(did`nt wanna throw a code right off). Hook up vac to fuel reg and crank to 40.5psi (just were it landed) . Ran koer with a repete 11 PASS, you heard me PASS,PASS,PASS!!! Ran car 15min. Idle great!! Even ran a/c to see if false hope. Nope , even with a/c on and sittibg in drive , idle steady. Came back home . Shut off engine . Restart. Ran koer again to see if just a fluke. Nope. Still an 11. Gonna run car for a few day`s and see if it holds. I drive alot while I work so we shall see but "BIG DADDY" I think u fixed it. I have learned a valuable lesson here in that throwing money at a problem is for uneducated people. I have about(truthfully) $900 in bull crap that I did not need. That would have been the majority of the money needed for a new set of performance heads as I am now out of money set aside for "goodies". Thanks again Joel50
06-01-2008, 09:34 AM   #96 (permalink)
Joel50
.... glad to read it's working the way it's supposed to......
If I may, and please don't interpret anything negative, I would like to use this thread as an example of how expensive solving a problem could get, if the "free" tools the system has are not used. You shouldn't have any problems, but if you do...... you know where to find me.
06-01-2008, 09:42 AM   #97 (permalink)
flocko
You may use these thread(s) any way you like!! Your the one that fixed the car not me. Further more, I take no offence to the above post . Facts are facts and if a person can`t learn from there mistakes then what has been accomplished?... not a darn thing!!
Idle problem flocko Late Model EFI Techboard 23 05-26-2008 08:26 AM
88 gt idle? timing problem ndmus88gteng Mustang Pages (1979-1995) 11 05-03-2008 01:55 PM
Idle problem flocko Mustang Pages (1979-1995) 0 04-26-2008 01:58 PM
Idle problem giddyup1 All Ford Techboard 3 07-14-2006 04:09 PM
idle problem 327notch Late Model EFI Techboard 0 11-15-2005 03:32 PM
