Originally Posted by flocko
F= Flash and * = the approximate lenght of the pause the best I could guess.
FF*F*F***F*F*****F***FFFF*F*FFFFFFFFF*F*FFFF*F*FFF FFFFFF*F. Test Complete I guess. No more flashes. One other thing I dont know. Does this computer throw 2 didget codes or 3 ?
Fast Flash + 11 + 11 + separator code + 41 + 91 + 41 + 91
Hard failure codes not present since 11 = system pass as On Demand codes
41/91 = engine is staying under lean condition in both banks for a long period of time as the Memory codes show.
41 - No o2 Sensor Switching Detected. always lean -passenger side(M)
91 - No o2 Sensor Switching Detected. always lean -driver side(M)
Suggest to run a KOER self test making sure the engine is at op temp (coolant temp >170° F) and LUK the results. The idle problem you have is due to a "permanent" lean condition affecting the system's adaptive strategy due to............stay tuned.
