Originally Posted by flocko
Got it! #4 is oviously in a koeo , #3 apears to be the same, koeo . I am assuming that "at engine temp" means that #1&2 are done in a koer state. How do you test an O2 with the engine running and plugs disconnected and not get a "check" light. Or do you just ignore it knowing that your in a test mode??????
#3 is a resistance/conductivity check of the heater element to mak esure it's not opened.....engine off key off.
#4 is KOEO.
If 3 & 4 are OK, you could test it twice....... O2 sensor disconnected (it generates its own voltage, that's how they work) ........and with the sensor connected probing the signal wire (pierced with a pin to connect the DVOM lead to).
If the CEL turns on while checking the O2s....... ignore it, you know why it's turning on.
