Originally Posted by Joel50
From those readings, you do have a lean condition in the engine...... the problem is reduced to ID'ing what is causing it. Fuel pressure is within specs and a new MAF was installed. The areas to concentrate on would be vacuum leaks (intake, MAF duct, PCV system, vacuum lines, etc)....... the BP/MAP sensor does not have a vacuum hose attached.....right? ...... redo a KOER self test in order to trigger a cylinder balance test after KOER codes are flashed (to id possible cylinder misfire caused by faulty injectors)...... exhaust leaks in the headers?
#1 New mass air sensor. Yes
#2 fuel press @ 43 psi Set with vac unhooked
#3 Maf ducting TIGHT!! Checked last night , all good
#4 No vac line to MAP. This is a MASS system. MAP only for barometric pressure. Were on same page so far.
#5 Little ball in PCV still rattles. Guess it is still good. About 4 year old. Line could be bad though??
#6 Put new vac line to charcol canister to intake last night . Did not help. Line looked like it came over on Mayflower!
#7 Going to finish #3 & #4 test. Will report
#8 Going to run KOER as you suggest. Will report.
P.S. One injector has a lot of "black" crap aroud the upper seal to rail. It is #2. Black "tracer" lines around upper to lower intake on pass. side. Intake was took off four year ago to port match to throttle bod. Be back soon. NOT JUMPING AT ANYTHING YET!!
