05-30-2008, 12:57 PM   #81 (permalink)
flocko
Re: Idle problem AGAIN!! NO WAY?
Originally Posted by Joel50 View Post
Go over the typical calibration procedures, make sure initial timing is 10° - 13° BTDC, redo the Base Idle Reset clear EEC memory (disconnect battery for 15 minutes) and test drive it again.
Ya , definatly a good idea to re check every thing. What , and I mean a BIG what has been possiably solved by plugging reg. vac line???
flocko is offline   Reply With Quote
05-30-2008, 02:20 PM   #82 (permalink)
Joel50
Lets check how it works with it disconnected first.......... LUK
Joel50 is offline   Reply With Quote
05-30-2008, 07:29 PM   #83 (permalink)
flocko
No problem. Had a BIG night last night and woke up this morn with a BIG head on my shoulders!! Had to lay back down this afternoon. Will reset everything in the morn. Will report back
05-31-2008, 11:12 AM   #84 (permalink)
flocko
Well , reset timing to 10 BTC, Reset TPS to .95v. Reset computer. Drove in different conditions for about 45min. NO ping and no idle issues. I can now unplug idle control vale and engine doese`nt die, runs a little rough with unplugged but it use to die. One thing that I did notice is that after a lot of driving and then pull in driveway put car in park that idle does not go back up to a "park idle" it kinda acts like it is still in drive. Normally idle in park and idle in drive a little different. Still idles good though.
05-31-2008, 06:21 PM   #85 (permalink)
Joel50
Rough as in lower? .... if so, at what rpms?
05-31-2008, 06:45 PM   #86 (permalink)
flocko
Well , hard to tell. I`m in the engine compartment. Cant see tach. Yes, rough as in lower. About 500rpm total.
05-31-2008, 06:48 PM   #87 (permalink)
flocko
Well , hard to tell. I`m in the engine compartmant. Cant see tach. Yes, rough as in lower. About 500rpm
When I first put all this "new stuff" on 4 year ago, I had no diff between idle control hooked up or not . Idled just the same. Now, idle RPM drop to 500 and rough if I unplug
05-31-2008, 06:53 PM   #88 (permalink)
Joel50
I think you're set...... the fact that there's no difference between rpms in Park and Drive = the IAC valve is doing its job controlling idle...... otherwise you would have lower rpms in D or too high in Park. LUK how it does in the long term.
05-31-2008, 06:56 PM   #89 (permalink)
flocko
No soulition, just leve fuel pressure reg pluged?????
05-31-2008, 08:22 PM   #90 (permalink)
Joel50
Damn!.........I forgot about that detail.... anyway!.... since you have an AFPR, it's a matter of increasing the FP with the vacuum line connected, until the lean codes are no longer present in a KOER self test. LUK
Idle problem flocko Late Model EFI Techboard 23 05-26-2008 09:26 AM
88 gt idle? timing problem ndmus88gteng Mustang Pages (1979-1995) 11 05-03-2008 02:55 PM
Idle problem flocko Mustang Pages (1979-1995) 0 04-26-2008 02:58 PM
Idle problem giddyup1 All Ford Techboard 3 07-14-2006 05:09 PM
idle problem 327notch Late Model EFI Techboard 0 11-15-2005 04:32 PM
