05-19-2008, 07:44 PM   #11 (permalink)
WUWU20
Re: Super Chip...96 T-Bird...Check Engine Light
Light came back on...lol I'm gonna have to pic up something to scan it with, got a factory manual off ebay today, thought I might need it.
1970 LTD 2dr ht
1996 Thunderbird 4.6
sniff, sniff.....who did that?
www.myspace.com/wuwu20
WUWU20 is offline   Reply With Quote
05-19-2008, 08:22 PM   #12 (permalink)
Likely an EGR issue...
Get it read
05-20-2008, 03:43 PM   #13 (permalink)
flocko
Good way to check is to start car, open hood, look at egr sideways and at the same time run up the rpm with your hand to about 2000rpm and you should be able to see piston on egr move. If not it is bad. Another way is to use a vacume pump as another person on this site just told me. Vacume pump cheap and can be used for a ton of stuff on a car. Egr should only activate at half throttle or so(crusing speed) NOT at idle or wide open throttle . Most Ford EGRs are specific to a paticular car and mine HAD to be purchased at Ford($75.) Make it simple . If you do replace it , take it with you when you go to buy the new one!!
flocko is offline   Reply With Quote
Check Engine Light in 96 GT Stangboy69 Late Model EFI Techboard 3 01-02-2007 07:44 PM
Check engine light 66fastback Truck Forum 4 06-15-2006 07:55 AM
CHECK ENGINE LIGHT nitroman Late Model EFI Techboard 5 12-11-2004 06:40 PM
4.6 96 check engine light yeraveragejoe All Ford Techboard 1 11-18-2003 09:38 PM
check engine light hyper1685 All Ford Techboard 1 09-11-2003 03:43 PM
